Creo 2, M100 Build
EricH
Creo 2, M100 Build
Has anyone upgraded and noticed any issues with the M100 build? Specifically not being able to activate Datums, Axis and Coordinate Systems?Creo2-M100.JPG
1 ACCEPTED SOLUTION
EricH
(To:EricH)
We traced this back to a conflict between the Config.Pro and Config.Sup files. What surprised me was; nothing was changed from the M090 versions but for some reason the M100 build didn't like the setup.
7 REPLIES 7
Dajagwar
3-Visitor
(To:EricH)
We just upgraded, and we do not have that issue. M100 actually fixed a lot of our issues.
Inoram
(To:EricH)
Same, I'm on m100 and have not seen that issue.
TomD.inPDX
(To:EricH)
I had this happened in M040 for some odd reason. Re-activating the part fixed it. Very odd and rare occurrence.
EricH
(To:EricH)
ngiacom
(To:EricH)
How did you solved the issue?
I have the same problem, but I don't understand how to fix it.
EricH
(To:ngiacom)
We had to comment out the following lines in our Config.SUP
! display_axis_tags yes
! display_coord_sys no
! display_coord_sys_tags yes
! display_planes no
! display_plane_tags yes
Speaking w/ PTC, one of the fixes between M090 and M100 highlighted this issue for us. Everything works fine, as expected. Hopefully this is your issue as well.
ngiacom
(To:EricH)
It works, thank you.
