Hello I just installed Creo 3.0 and noticed nice improvements within Freestyle feature, but also noticed missing features like Solid Free Form or Surface Free Form.
My question to the Audience is: will Freestyle cover the functionality of mentioned missing features?
BR
Roman
Per the help documentation:
To Create a Freeform Surface or Quilt
1. Set the enable_obsoleted_features configuration option to yes. The Surface Free Form command appears on the Commands Not in the Ribbon list.
2. Add the Surface Free Form command to the desired user-defined group on the ribbon.
Note: For information about customizing the ribbon, see the Related Links.
3. Click Surface Free Form. The SURFACE: Free Form dialog box opens
enable_obsoleted_features yes, no*
Enables the following commands on the Commands Not in the Ribbon list when set to yes:
• Blend Between Surfaces
• Blend Section to Surfaces
• Conic Surface and N-sided Patch
• General Blend
• Pipe
• Project Section Blend
• Solid Free Form
• Surface Free Form
• General Blend
• Pipe
• Solid Free Form
• Surface Free Form
Great thanks for your valuable and fast response!
I also set to yes "allow_anatomic_features" and have got ability to use e.g. local push and more
Thanks again and regards
Roman
what happens when a person without those settings open the file?
and why would they take out tools if there isn't a better replacement? or is there?
If you'll open a part with those features you'll se them without any problem and of course you'll be able to redefine it. Only without those settings you can't add them.
I gues at the beginning that PTC remove those features and that was the source of my investigations - perhaps in future they create something new. At the moment the best candidate from my point of view is Freestyle - after surface creation with this feature you'll be able to use replace surface or just solidify etc.
