Creo 4.0 extrude cut-out graphics issue
SOLVED
Re: Creo 4.0 extrude cut-out graphics issue
Here we go.
Opens fine for me.  Hole and slot are both there.  Seems like maybe a graphics specific issue on your computer (like @dgschaefer said.)
What build of Creo 4 are you running?
Look for the config option "enable_absolute_accuracy" and set it to yes.  That should let you use absolute accuracy.  I've been using Creo / Proe for over 20 years and have always used absolute accuracy and recommend it as the default.  I'd try it, it still might do the trick but it seems unlikely based on the other things you've tried.
Doug Schaefer | Engineering Manager
Crow Works
I opened your file and saw the same thing as you on my computer.  I changed to absolute accuracy (0.0001) and the problem went away.
Crow Works
@TomU wrote:
Doug, what build are you running?
Creo 4, M020.
Crow Works
My file in program data states it's f000. I'm in the works of updating my software too. When I get back to the office, I'll check out that enable absolute accuracy as well.
I appreciate all the help you guys have given and hope this next attempt will will work.
Okay, I just retested again.  I can reproduce the issue in all of these Creo Parametric versions:
  • 4.0 M030
  • 4.0 M040
  • 4.0 M050
  • 5.0.0.0
  • 5.0.1.0
I cannot reproduce the issue in Creo Parametric 4.0 M060.
Creo4 m060 was the last released in early August.
Creo 5.0.1.0 was released in early July.
Hopefully it will be fixed in Creo 5.0.2.0 scheduled for early October.
Unfortunately, this did not fix my problem and this unwanted surface is still appearing.
What version did you upgrade to?
