Creo Advanced Rendering video tutorials
Hi folks,
... for everybody who like Creo rendering >> I have finished my tutorials for you  - do not forget enjoy it, learn something new, share and comment.
Best Regards,
your virtual application engineer for Creo Parametric,
Vladimir Palffy
Creo Parametric video tutorials - Advanced Rendering with Creo 3.0:
o Color Definition
• Photolux Properties: Reflection color
• Photolux Properties: Diffuse
• Photolux Properties: Reflectivity
• Photolux Properties: Glossiness
• Photolux Properties: Transparency
• Photolux Properties: Translucent vs. Transparent
• Photolux Properties: Refractive Index
• Photolux Properties: Metallic color
o Used Lights in Render scene
Best Regards,
Vladimir Palffy
5 REPLIES 5
Re: Creo Advanced Rendering video tutorials
Fantastic job.
Thanks for sharing.
Marco
Thank you, Vladimir.
Who is the best one?
Asnwer is simply: Vladimir Palffy is the best one!
Thanks Vladimir
Thanks Vladimir,
Are these applicable to Creo 2.0 also?
With regards,
Soumya
Hi Soumya,
every feature and functions are in the Creo 2.0 (not same but logic is same).
Note: Real time rendering in perspective mode is not so perfect like in Creo 3.0 and Creo 4.0 , but is not problem ... I have created a lot of renderings with ProENGINEER and Creo 2.0 >> I have used (and still use) function Render Region, if I need to check some part of a rendered scene.
Regards, Vladimir
Best Regards,
Vladimir Palffy
