Here is a collection of known keyboard accelerators (hotkeys) for Creo Parametric 3.0
Accelerator | Name | Description |
Ctrl+K | Hyperlink | Add, edit, or remove a hyperlink to the selected text. |
Ctrl+G | Regenerate | Regenerate the model. In drawing mode also redraws all views. |
Ctrl+F | Find | Search for, filter, and select items in the model by rules. |
Ctrl+A | Activate | Activate this window. (Should not be necessary in Creo 3 - windows are supposed to automatically activate.) |
Ctrl+N | New | Create a new model |
Ctrl+O | Open | Open an existing model. |
Ctrl+S | Save | Save the opened model. |
Ctrl+P | Print the active object. | |
Ctrl+Z | Undo |
Undo the last action. (Only valid for certain actions.) |
Ctrl+Y | Redo | Redo the last action. (Only possible if undo was used. Not "repeat".) |
Ctrl+C | Copy | Copy |
Ctrl+V | Paste | Paste (Not the same as "paste special".) |
Ctrl+D | Standard Orientation | Display the object in a standard orientation. |
Ctrl+F1 | Hide Ribbon | Toggles display of the ribbon on and off. |
F10 or Alt | Activate Shortcut Keys | Activate (and display) shortcut keys for all displayed commands. |
Ctrl+R | Repaint | Redraw the current view. |
DEL | Delete | Delete the currently selected item. |
This document was generated from the following discussion: Creo 3.0 Keyboard Accelerators (Hotkeys)
