Creo Parametric 3.0 Templates don't work/load when trying to create a new part, why?
Thaks in advance for any information.
if you want to create your own startup part, then:
MH
Hi Jose,
If you are trying to access the default templates, they are installed in the following location, with the Creo 3.0 installation:
<drive_letter>:\<install_folder>\Creo 3.0\<datecode>\Common Files\templates
Please check if this folder is accessible.
Amit
