Creo drawing datum curve from equation inaccurately
SOLVED
Re: Creo drawing datum curve from equation inaccurately
Yes, I've set up all of my start parts to have absolute accuracy since we switched from Pro/E to Creo and this type of stuff started to crop up. Unfortunately, whenever I pull in an old model from the long ago (we've been using Pro/E -> Creo since about 1993), it defaults to the relative accuracy, and "fixing" it sometimes causes the models to fail. It's fun.
It's even more fun when you're using the manufacturing module, and weird behaviors occur when accuracy is not set to a small enough value. Again, oodles of head-scratching and vulgarity-spewing fun.
Interesting.  I guess I didn't even think to mention it because for one thing, I've always used absolute .0001 or better when needed, and I figured (erroneously) that they would have already tried that.  I think that's the biggest revelation for newer users and based on the equations didn't think they were one.
Well, glad it was an easy solution!  Weird that the problem showed up ONLY at the tip (just the tip...  LOL)...
I've never seen where older models default to relative accuracy, thanks for the heads up!
I HAVE seen where, with complex surfaces, and especially their rounds (IM plastic), things fail when using an absolute accuracy value too small (.0000001 vs .0001).  There seems to be a sweet spot where the "fudge factor" works when nothing else will.  I've had to slowly step the value down or up until the features all (or most) work.
@KenFarley wrote:..oodles of head-scratching and vulgarity-spewing fun.
I believe I'm experiencing some of that right now.
At first I could not understand why I was unable to change my accuracy settings from relative to absolute.
It turns out that I had to first enable the ability to choose absolute accuracy in the configuration editor with enable_absolute_accuracy = yes. I do not understand why this is a thing in the first place.
The fun doesn't stop there. You see when I try to set my absolute accuracy to something reasonably low, I am denied and get told this weird range of values that I must set my accuracy within:
Even better, this range seems to change by some magical means unknown to me (something I do seems to affect it):
What can't I set my absolute accuracy value to 0.001 or lower like other people have suggested? Why am I getting this weird range of accuracy bounds?
All this hassle just to properly draw a curve from an equation. I've spent more time troubleshooting than I have doing actual work. On the bright side, the curve is looking better (absolute accuracy of 0.006):
No more inflection. But the very tip is just a tiny bit too inaccurate in shape.
Any way I can set my accuracy lower to 0.001 or 0.000001?
There are a couple of settings that I have in my config.pro file that might help:
accuracy_lower_bound
default_abs_accuracy
I don't know what the default for these is, but maybe that's what is causing your troubles. I have both set to 0.00001 in my config.pro file and it works fine, don't know if there is some sort of hard-coded limit built into the software.
If you're using inches for your model, 0.001 is probably not precise enough.
Changing the accuracy from relative to absolute in an existing model can be a real time sink. To avoid this hassle set up start parts with absolute accuracy to use for all newly created parts. Relative accuracy is a dimensionless parameter and changes based on the bounding box of the model. Absolute accuracy has units of length and does not change unless the user changes it.
With the accuracy config options set up, create a start part without any features with the desired accuracy. I used .001 mm for this example. Then copy/paste the curve into the start part or rebuild it.
I agree.  I think starting over with a fresh start part with the absolute accuracy already set to .0001 or smaller, would be the best thing to get a good curve.  I've used that setting for years and it seems to work well for all but the trickiest surfaces.
Best of luck!
It's not a "hassle" and there's nothing wrong with (that part of) the software.  If you're going to make complicated models, your start parts should have been made with absolute accuracy set to .0001" or lower to begin with.  It's a rookie mistake but we've all been there.  The first time I ran across it was in '96 when first learning Pro/E (as it was called then - I still prefer it).  I had a long, thin part, with a small hole on the end.  It flat refuse to regenerate the hole at all.  Looking into it, I found the right settings, and since then have had few problems.  The exception being sometimes having to "tweak" the absolute accuracy to get ALL the features to regenerate.  For simple models with small differences between the minimum feature size vs the maximum feature size (actually as I understand it, tesselated triangle size), relative accuracy works fine and save files size, sometimes significantly.
The reason you're getting a range of numbers, is because you already have some features on there that WILL fail if you picked a number outside that range, so it prevents you from doing so by limiting your choice.  That's why it's best to start with a fresh part with no geometry besides datum planes, cs's, axiis, etc.  Then it allows you to pick any value you want except a number below the lower accuracy limit.  If you know you're going to be modeling a part with crazy complex surfaces, tweak that absolute setting lower before you make solid or surface geometry.
Now you know, and your models should be better for it.  Not bashing you, it's just a learning process we've gone thru before you did.  It's not a show-stopper and again, it's not a software issue.
Best of luck!
I added those settings to my config.pro file which avoided the constraint of the accuracy range and I was finally able to get a very nice looking curve towards the tip:
Thank you very much.
My problem has been more than resolved.
Fair enough, but it seems counter-productive and not very intuitive to completely hide such an important setting, by default, behind a config line. I almost always started every part I've made with the best "relative" accuracy allowed but up until this thread, I did not even know an "absolute" accuracy setting existed since it doesn't even show up as an option in the Model Properties until you've added enable_absolute_accuracy in the config. Why not just have the option available as a choice from the beginning?
Not trying to be difficult; just genuinely curious as to the reasoning behind why Creo is setup this way by default.
Yes, but the erratic range of numbers happens even on a new part with no features:
Thankfully, the two previously mentioned config settings avoids this altogether but I'm still curious as to why this happens.
