Creo equivalent of SolidWorks configurations in parts?
acoates
Hi there,
I've been with a new company using Creo 2.0 for the last three months and we would really benefit from being able to create parts with what I know as "configurations": I'm not sure what the equivalent term in Creo would be, I'm afraid.
The first parts I am trying to create are bent plates. There are 8 different versions, each sharing all bar two dimensions: an angle and the overall length which is driven by the angle. I've attached a 2d draft to demonstrate.
My target is a single part with 8 "configurations", with one drawing displaying this part in a default "configuration" and a table that will define parameters 'A' and 'L'.
I hope that this is feasible in Creo as it would save a lot of work!
Many thanks in advance.
1 ACCEPTED SOLUTION
Mahesh_Sharma
22-Sapphire I
(To:acoates)
Hi Andy,
Family table in Creo Parametric is as Configuration in Solidworks and to use that functionality:
1. Create the part as sketch you attached.
2. Select Tools > Family Table
3. Click “Insert a new instances at selected row”, one click will add one row and click on that as per your number of instances (click 8 times will create 8 rows for 8 instances)
4. Now select “Add/Delete the table columns” and set Dimension user Ass Item
5. Click on part and select required dimensions to add in Family Table > Ok
6. Replace Asterisk (*) with new values for dimensions and finally “Verify instances of the family”.
Mahesh
Mahesh_Sharma
22-Sapphire I
(To:acoates)
Hi Andy,
Mahesh
Brilliant. Thank you, Mahesh. That has worked and the instances have stayed controlled when testing in and out of Windchill.
Kind regards,
Andy
