Creo file size with zero features is 3052kb. Any idea why is it so?
hvyas-3
6-Contributor
I have a creo file with no features but its file size is 3052 kb. I would appreciate your response. Please find the file attached.
9 REPLIES 9
Chris3
20-Turquoise
(To:hvyas-3)
Do you have any appearances with image maps?
hvyas-3
6-Contributor
(To:Chris3)
No
KenFarley
(To:hvyas-3)
It must be an old file that has had stuff deleted from it, yes? I just created a new file (Creo 4.0, M090) with no template (empty) and its size is 34Kb. I think there's a lot of "baggage" and other remnants of stuff left in a file even after all the features have been deleted. I don't know what kind of persistent junk is retained in the part database, but I wish there were a way to purge it.
hvyas-3
6-Contributor
(To:KenFarley)
It's from CREO 3.0 M160. I don't know reason behind it, But definitely need it.
please upload the file.
Martin Hanák
hvyas-3
6-Contributor
(To:MartinHanak)
Hi Martin,
Please find it attached.
Best,
Harsh
@hvyas-3 wrote:
Hi Martin,
Best,
Harsh
1.] there is some history saved in the file, for example it was saved in Windchill Commonspace
2.] I guess the file was improperly cleaned
3.] you have to send the file to PTC Support if you want to get the answer to your question
4.] I opened the file in Notepad++, as you can see in the following picture the file contains thousands of strange lines corresponding to excessive data.
Martin Hanák
BenLoosli
23-Emerald II
(To:hvyas-3)
Is this a new file created in Creo 3 M160?
Is it an older file that has had the features deleted from?
Are there any relations or parameters in the file?
Are you using Windchill with your files?
There are many reasons a file size grows and does not shrink when objects are removed.
Patriot_1776
(To:hvyas-3)
Are there a ton of parameters and relations that calculate values?
