Cross-Section View with Z-Clip
AndrewFeisthamm
So here is my problem...I have a view showing a total cross-section and I would like to not show all of the geometry behind the section, only some of it. However, when I try to add a z-clip, the hatch disappears. The strange part is that it still exists, because it highlights when I put my mouse over it and when I select it, but as soon as I unselect it, the hatch goes away. I suppose I could accomplish the same thing by using a combination of component display and edge display, but that gets kind of cumbersome. Any other suggestions???
double check that your datum plane for the section is going in the correct direction, usally when i have this problem all i do is flip the plane and that fixes it.
Yeah, I already tried that. The section is pointed to the correct direction and the Z-Clip reference is also on the correct side of the section.
try removing the hatching before applying z-clip. ankur
