Cutout in creo 2.0
vora5678
Cutout in creo 2.0
What is the setting for cutout operations in assembly
And how to do it ?
This type of error are occure
1 ACCEPTED SOLUTION
@vora5678 wrote:
And this operation is not shown in model tree history...
It should be, in the part.
Check your model tree settings. Are features turned off in assy mode?
LinkedIn
5 REPLIES 5
The error message provides a clue which is easy to understand once you know the lingo -- the part you are trying "cut out" is packaged - that is, it is not fully constrained.  In your model tree, you'll probably see a small rectangle drawn next to the part icon.  Apply additional constraints until the icon disappears and then try the cut-out process again...
vora5678
(To:pausob)
LinkedIn
vora5678
(To:dgschaefer)
Im not sure for feature are disabled in assembly is that any perticular settings?
Check your model tree settings, I think they are turned off in assy mode by default.
LinkedIn
