Cuts and Protrusions Normal to a Surface
Newbie
I have a case where I need to make a cut or a protrusion on a warped surface
that was created using a variable section sweep. The part is a trapazoidal
shape that follows several curves to be able to fit another part over a
distance. All I have at this point is a plane that goes through the center
of the part along with a datum curve on the surface through the datum plane
and the surface where I need to create the cut. I have created a point along
this curve as the location for the cut or protrusion. Now I am at a loss as
how to create the protrusion or cut normal to the surface at this point.
I am using Pro 2001.
Any suggestions?
Thanks in advance,
Dwayne Quatier
QTech Consulting
