DRAGGING OPTIONS
SOLVED
Amethyst
DRAGGING OPTIONS
which is the option to change the number of entity dragging, for example, if i make points i can only move them dinamically by 10 but i want to move by 1 for instance.
thanks
Re: DRAGGING OPTIONS
You can set handle movement with different config.pro options that are unit dependent.
The config.pro options are:
millimeter_grid_interval
centimeter_grid_interval
meter_grid_interval
angle_grid_interval
inch_grid_interval
foot_grid_interval
So if your current units are millimeters, and you set value on 1, than when you drag the handle of a edited feature it will move by 1 mm.
Be more specific. I feel we can sort this out
see video attached Video Link : 5816
meter_grid_interval
angle_grid_interval
inch_grid_interval
foot_grid_interval
