Designate parameters in relations window
Level 10
is there some way to designate a parameter (defined in the relations window) directly in the relations window itself, with some sort of string special character?
(Otherwise each time one has to close the relations window and open the parameters one, and tick on designate...).
thanks
Tommaso
8 REPLIES 8
Re: Designate parameters in relations window
if you expand Local Parameters area in Relations dialog box, you can designate model parameters.
MH
Martin Hanák
Hi Martin,
thanks for your reply. In this way however one still has to close the window, regen, and then re-open it to see the parameter in the list.
Or is there a way to make it visible in the list without closing, regen and re-opening?
What I am searching is a possible string or way to set it once and for all directly in that window.
bye
All you have to do is press the verify button after defining the relations
& parameter will show up in the window, designate box can be checked off/on at this stage without the need to regenerate
Pushkar
Hi Pushkar,
ok thank you, indeed Martin's and yours advice can be a good workaround.
bye
Tommaso
There is no way to auto-designate the param created by relation. One way could be to predefine the param in the start part, but rather than that consider using ModelCHECK or the mapkey method described here designation of parameter by mododel check
Hi James,
your first suggestion about including the param in the start part, I have already made it for internal parts, indeed I forgot to specifiy in the post that my enquiry is meant for the external parts which I download from tracesparts for example, who are imported with no relations at all (unless there is the possibility to define a sort of "importing" start part also for these items, which would be extremely useful to my use)..
I read the ModelCheck post with the mapkey, yes indeed can be a way to do it and it requires a click or key press more, just like the verify button suggested by Pushkar so it would as quick as it. (I was wondering whether ther was a string to avoid further clicks or key press but seems there is no way).
thanks
bye
Tommaso
If it's a STEP, IGES file or any other universal format then it can be loaded to Creo using start prt and start asm. Even an assembly and all of it's sub assemblies with parts can have parameters, relations, layers etc. loaded automatically using this method.
import step with start parts
Either way, I still recommend to have a look at ModelCHECK and the ModelUPDATE functionality it offers especially for Interactive Mode. In a long run it saves a ton of time that is otherwise spent on manual fixing of the existing/legacy models.
http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/#page/pma/model_analysis/ModelCHECK_Overview.html
Thanks a lot James!!
I had also searched about this possibility but didn't find anything, maybe also because that option is not mentioned by default in the "options" UI in Parametric...
Yes indeed I don't know what ModelCheck is yet, but I will get informed about it.
Have a nice day,
Tommaso
