Determine if a part is suppressed with relations or PRO/Program?
Newbie
See attached image. I would like to be able to suppress the pink part and have the holes/notch in the gray part suppress along with it. I know I can do this with a parameter/family table, but it would be much easier if I could avoid that. We have a lot of similar intersections and a parameter definition for each one would become unwieldy. Is this possible?
Re: Determine if a part is suppressed with relations or PRO/Program?
Actually this looks like exactly what I need, too bad I'm on Wildfire 3
PTC Creo Options Modeler | PTC
if holes use references from pink component, then they will be suppressed, too. Pleas upload test assembly to enable community members to investigate, how your assembly is created. Use How to attach file when you Reply to a discussion. procedure for file uploading.
MH
Martin Hanák
