Diameter dimension as default for circles.
SOLVED
Highlighted
Regular Member
Hi
I have weak dimensions turned off.
I find it annoying in sketching, when you attached a dimension to a circle, it defaults to radius.
It would be more intuitive to have it default to radius dimension for arcs only.
Anyone agree?
Any way to set this functionality?
Cheers!
Rick in Mississauga,
1 ACCEPTED SOLUTION
Highlighted
Re: Diameter dimension as default for circles.
Hi. Click once on the circle to create a radius dimension. Double click to create a diameter dimension. Does that help, or did I misunderstand your issue?
4 REPLIES 4
Highlighted
Turn on weak dimensions.
When I create a circle in sketch, it comes in with the diameter.
Highlighted
Oh, turning off weak dimensions is bad. The underlying dimension is still there, just hidden.
It's your hint there is something missing or not constrained correctly. Usually not a problem with simple stuff but anything with complication, not seeing the weak dimensions may be the difference between a usuable part and scrap.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Highlighted
Bingo Pettersson! That's the secret trick I wanted.
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
