I mentor a FIRST FTC team. I am a beginner when it comes to Creo. We are using Creo Elements/Pro School edition on a Windows 7 laptop. I have downloaded the FTC 2011 KOP.
When I try to mate to elements of the kit of parts, I select the Placement tab, and attempt to select a face of one part to establish a constraint with another element. As soon as I select the face, my screen becomes filled with lines (see attached picture) and I am unable to continue. Any suggestions? I didn't have the problem when I used ProE on the same computer.
Lance
My High School age son had the answer for me:
To fix this go "Tools" => "Options". A window will open with various settings. Type "graphics" into the search bar at the bottom. Change the value from "openGL" to "win32_gdi". Click "Apply/Change". Search for "use_software_openGL". Change it to "yes". Click "Apply/Change".
Click "OK". Restart Creo. Problem should be fixed.
It worked!
It worked!
