Dimensioning help
A.DelNegro
Dimensioning help
I have this bent fitting that I need a little help with. The red dim is the radius of the bend in the centerline. IF I show the sketch from sweep, the arc is blue and prints pretty weird. I assume I would really want a curved centerline there. Is there an easy way to show this or create it there? Is there a different way you would suggest dimensioning this?
[cid:image001.png@01D0559A.C5FD9800]
Hi Tony,
Showing the sketch from the model is the way I would do it - that's generally the most robust approach.
You can change the line colour and type in the model - select the sketch, then RMB -> Properties, IIRC.
HTH,
Jonathan
