Can anyone knows the way to disassociate the link between the drawing and model.
I want only the drawing in .drw file without the part in the model tree
You can convert each view to use draft entities and then remove the model.
Creo 2.0
Layout > Edit > Convert to Draft Group
Creo 2.0
Thanks Mark, your inputs got worked for me.
Prabhu,
You should set Mark's answer as correct for those who may search on this topic in the future and find this discussion.
Thanks, Dale
