I'd like to be able to tell at a glance when I'm opening a sketch whether something is a radius or diameter dimension. Is there a way I can make so that these dimensions will always automatically appear in the sketcher with the respective prefix, i.e. R for radii and D or ⌀ for diameters?
It's easy, when you see the double arrows on the left, it's a diameter, the single arrow on the right denotes radius.
Ahh I see. Bummer. Thanks!
