Draft Split at Datum Curve
Newbie
I have a part that has a parting line that is not straight. Please see
83847_1.jpg for an illustration. The parting line runs horizontal thru
the center of the part and then angles down. I cannot figure out how to
create the draft feature. I think the problem I have is in not knowing
what to use for the reference direction.
I could go on and on about what I have tried. I think I used almost
every combination of split at sketch, split at surface, draft offset,
etc.
An iso view of the part is shown in 83847_2.jpg. It also has the 3
planes showing. I need to get this part to a casting source today as
they are making the tool from my model. Can anyone give me a hint as to
how to use split drafts?
Thanks in advance,
Kenneth A. Dodd
Senior Designer
Ausco Products, Inc.
dodd@auscoproducts.com
Phone 269 926 0772
Fax 269 926 0836
Re: Draft Split at Datum Curve
Is this more or less what you want?
If so, use the horizontal plane as the reference.
Rui
"Ken Dodd" <dodd@auscoproducts.com> wrote in message news:39301@model...
I have a part that has a parting line that is not straight. Please see 83847_1.jpg for an illustration. The parting line runs horizontal thru the center of the part and then angles down. I cannot figure out how to create the draft feature. I think the problem I have is in not knowing what to use for the reference direction.
I could go on and on about what I have tried. I think I used almost every combination of split at sketch, split at surface, draft offset, etc.
An iso view of the part is shown in 83847_2.jpg. It also has the 3 planes showing. I need to get this part to a casting source today as they are making the tool from my model. Can anyone give me a hint as to how to use split drafts?
Thanks in advance,
Kenneth A. Dodd
Senior Designer
Phone 269 926 0772
Fax 269 926 0836
