Drawing Table Parameters to create a Table-of-Contents for multi-sheet drawings
Amethyst
Drawings with multiple sheets need a Table of Contents - just like any other multi-page document.   Report repeat region parameters would need to be established for just this purpose.  A Table of Contents should be just as easy to implement as a Bill of Materials.  A parametric Table of Contents would update any time a sheet is added, or is re-named or moved in sequence.  A sheet revision date parameter would be appropriate also.
