Drawing Tree
ptc-5177357
Drawing Tree
I am working in Pro/E Wildfire 3.
I could not get the "Drawing Tree" in the drawing file, I feel that this is because of some incorrect settings.
Could any one help me to get it out.
Thanks and Regards
Perumal
I'm not a Creo/ProE user but I am sure you have more luck if you
1) start a discussion (flagged as a question by default) rather than a blog post
2) post in an appropriate section of this community, I guess Creo
http://communities.ptc.com/community/creo?view=discussions
Good luck!
Hi Perumal...
First, Werner's message (above) is correct. You'll get much faster responses by posting your questions as a discussion rather than as a blog.
Second, unless I am not remembering correctly, there is no drawing tree in Wildfire 3.0. I believe the drawing tree appears for the first time in Wildfire 5.0 (aka Creo Elements/Pro 5). At Wildfire 2, 3, and 4 you only have a model tree.
I haven't used Wildfire 3 for about 2 1/2 years so I could be wrong. I just wiped out all old versions of Pro/E prior to Wildfire 5 so I cannot go back and take a look. I think you may be looking for an option that does not exist.
Maybe someone else on WF3 can verify?
Thanks!
-Brian
