Drawing:un-wanted number out of the repeat region table
SOLVED
Newbie
In my 2D drawing i use tables with repeat region of different parameters.
At the end of the table, out of that come into wiew the last parameters of the table, as shown in the picture.
I need to delete the black numbers.
Re: Drawing:un-wanted number out of the repeat region table
Luca,
next to the right outer border line of the table there is a "hidden" column containing &rpt.rel.massa_parziale parameter.
Activate Table tab, set selection filter to Table Cell, place mouse cursor near the border line and Zoom In several times until you see "hidden" column. Mouse cursor must be placed left of border line.
Select the cell, press RMB and click Properties. The selected cell must belong to the row, where report parameters are entered !!!
Remove &rpt.rel.massa_parziale parameter.
Martin Hanak
Martin Hanák
11 REPLIES 11
Can you do a "switch dims" to show what the repeat region parameter is being displayed?
Here in the note properties window!
Weird. Are you able to share your drawing or even just the table itself? (You can upload using the advanced editor - link in upper right corner of reply window.)
this is my table template!
I'm not seeing the extra numbers when I use your table.
Are you able to share your assembly and drawing?
Luca,
please show us Note properties of black number.
Martin Hanak
Martin Hanák
The only way to select these note is by text style, but is shown the note ID:
Something is weird here. Is this reproducible on a new drawing of the same assembly, using the same table and repeat region?
I see this problem every time that i use this table, in every drawing.
I've attachment an example of drawing and its assembly with the table.
Luca,
Martin Hanak
Martin Hanák
You right, thanks!!
Thanks you all for the support!
