Drop test simulation - Mechanism damping
ghorvath
1-Newbie
Hi PTC Fellows,
I need help for my Mechanism simulations. I'm working on a drop test analysis. This means the impacts between the granite/concrete/steel blocks and danamid/aluminium specimens. Creo needs to know the mechanism damping [sec/mm] for both materials. (3D contact as constrain)
Can anybody help me? How can I determined this parameters? Measurement (3db bandwidth or logarithmic decrement method)? Is there a summary table for several materials?
Thanks for the helping
3 REPLIES 3
Hello Denis,
Thanks for your answer.
The second link was helpful, but I'm looking for a table which included the correct parameters. I found on the internet a study about the dampings:
http://teaching.ust.hk/~mech300/mech300_7_1_damping_ref.pdf
But I'm not sure which damping needs me. (viscous damping ratio, material damping, loss factor, etc) First of all I have to clarify it.
I tried the 0.008 for the concrete block and 0.001 for aluminium specimen but the result of the simulation does not seem real. The local PTC support said me that I need to "iterate" these parameters based on the experience of the test.
Regards, Gyorgy
DenisJaunin
(To:ghorvath)
Hello, Gyorgy,
I have a paper on the subject, but in French, if you do not dérenge.
Cordially.
Denis.
http://www.sendspace.com/file/4vx7st
