Hi Folks
I have patterned 1 feature 90 degrees. It is a simple rectangular block that I have patterned once. I would like to alter the hieght of one of the blocks - is there a way of doing this without both of them changing?
I found this option under Copy/Paste Special. You can paste using a rotation and Fully dependent. When you edit a feature in the copy, it will ask you if you want to make it independent.
In the example, I copied the left hole to the right (60 degree rotation about the center axis) and varied its diameter using edit.
