Error loading homebrew in Creo Elements/Direct Modeling
SOLVED
Newbie
Faced this error when I opened the application.
Does anyone have any idea to solve this?
Tags (1)
1 ACCEPTED SOLUTION
Re: Error loading homebrew in Creo Elements/Direct Modeling
HomeBrew is customization of Creo Elements/Direct Modeling for HP Inc. If you are getting an error, contact me with the specific error message.
6 REPLIES 6
do you have any customization? or do you run Creo elements/Direct Modeling out of the box?
I have the same question for this.
I install HomeBrew and my PCB can't open.
Hi Huang, you may refer to the answer/solution above
Huang,
You may contact me if you are having problems with HomeBrew.
Hi, Peter
Thank you for your replay.
When I open the HomeBrew PCB , I don't know how can I import EE data.
refer picture
Because I open PCB from regular Creo E/D , I can import data.
refer picture
But I can't look for Import form the HomeBrew PCB.
