Export Formula Driven Lattice to STEP or IGES format
SOLVED
Guest
Please how to export (save as) lattice formula driven (gyroid, diamond, primitive) to a step or iges format file ? I found this article. But I could not open it. https://www.ptc.com/en/support/article/CS303867
Re: Export Formula Driven Lattice to STEP or IGES format
requested fuctionality is not available. See attached document.
Martin Hanák
Martin Hanák
Ok, thank you for your answer 🙂
