Export all combined views to 1 PDF
SOLVED
BWS
Contributor
How can I export all combined views (tabs in the bottom) into a "merged" pdf?
1 ACCEPTED SOLUTION
Highlighted
Re: Export all combined views to 1 PDF
I am not familiar with .pcf files.
A mapkey could easily be set up to automate the print process up to the Printer Manager.
Creo is an endless adventure: Always more to learn.
3 REPLIES 3
Use File/Print.
On general tab:
  • Printer should be MS Printer Manager.
  • in Combined States box, select All.
  • Select OK
From Printer manager select PDF then OK.
Would it be possible to have these settings saved as a .pcf file, and run it by a command or button?
If yes, are there any guides on how to make them? I've searched on google, and the .pcf files are not working for me 😞
Highlighted
