I am trying to do an exteranal thread callout. The only way I can do it is through a cosmetic thread. However, certain parameters cannot be defined, such as pitch thread type etc... How do I make this thread a callout, and also make it an annotation similar to defineing a thread using the hole command.
D
I was looking up the same information. If anyone has the answer, I sure would like to see it. I know that internal threads are controlled by .HOL files, and I thought I saw somewhere that external threads use the same files, but I can't seem to find it again.
I am looking for the same. Cosmetic thread added, now how do you display that annotation on the print?
