In Extrude command, There is this option, attached or unattached, I didn't found any utility for this. What's it intend?
In sheet metal?
Those are state of geometry preview within the feature creation user-interface.
Attached—Displays the geometry as it appears when you finalize the feature.
Unattached—Displays the outline of the geometry you are defining.
Config option 'dynamic_preview' controls the default preview state.
For better display, Create a solid box and on that create a hole. When creating hole use Attached or Unattached.
So, it works only for the preview option
yes.
