Family Table Repeat Region...
Highlighted
Newbie
Is there a way to create a repeat region on a drawing of a part with a family table and NOT have it display all the rows of the family table? I was given a work around where you create a seperate repeat region for each row of the family table and then create a filter to set the value to the family table row name. Sure seems like there should be a way to do this DIRECTLY just by entering the right, specific coding into a multirow repeat region to have it display correctly. Anyone know how to do this?
Highlighted
Hi Paul,
Attached a repeat region for a generic part which can be filtered on instance names (rows) and on parameter names (columns)
Take this Family Table:
With the attached repeat region you can create the following table on a drawing
By adding these filters:
Kind regards,
Olaf Corten
Olaf Corten | CAD/PLM Manager
Besi Netherlands B.V. | Ratio 6| 6921RW Duiven| The Netherlands
T: +31 26 3196215 | M: +31 644548554
- | www.besi.com
To: -
Date: 10-07-2014 17:24
Subject: [proecad] - Family Table Repeat Region...
Site Links: View post online View mailing list online Start new thread via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
Highlighted
RE: Family Table Repeat Region...
That sounds really "messed up", it's actually fairly simple and is covered in Help. Unless they improved upon the topic it isn't too clear without a little reasoning or effort. If I recall correctly you create the 2D Repeat Region and then write a filter listing either the familytable columns you don't want displayed, or possibly the ones youdo want displayed, seperated by a coma. It's been a little while since I worked on one. It's actually pretty straight forward once you get the logic.
