Free moving string? Like a rope?
ptc-5188141
Is it possible to create a string in pro/e creo? I'm thinking the only alternative would be a chain...but wouldn't produce the same results as the model I am trying to create.
When I searched for it all that was returned were all programming strings, not the physical string.
8 REPLIES 8
What level of detail do you want? The easy way it to sweep a circle on a guide and map a nice "string-like" texture on it. If you want the 3D texture of a string twisted in the model, you can also use Sweep but use variable section sweep to get a twist to is. If you want a "woven" string, again, VSS but mesh a second sweep in the opposite direction. How much horsepower do you have in your computer?
BTW, with a little reading, you can also get a applied texture to have "roughness" using the renderer. That is the bump when you create a material with a texture. It takes some knowhow and work to have it come out close to real.
Why? As Antonius said, you can create a string geometrically correct, but it'll be a tremendous challenge and chunk of time doing it. You'll have many levels of VSS's, IF it regenerates at all. Fudge it if you can.
SylvainA.
(To:ptc-5188141)
What do you mean by "free moving"?
Do you want that the string moves when dragging a component it is attached to?
Dale_Rosema
(To:SylvainA.)
Sort of like a "free range" chicken - not caged. - Sorry a little punchy this morning.
Doh!
I guess the correct term would be a soft body. But I've only seen that done in other programs like blender. All I need is a wave to be able to travel down the string.
It seems like a feature that should be merged into creo. Of course rendering would be painful. Lol.
I disagree. There's no need for that in a strictly CAD program. What you're looking for is in an animation package like Maya, or Alias/Wavefront etc.
If you have a need aside from one project, Rhino3d is inexpensive and a great tool by itself to have in your arsenal of tools. http://www.rhino3d.com/
They have an animation plugin with IK and it's really easy to use. http://www.bongo3d.com/index.htm
Another plugin for Rhino that has some animation tools and much much more (this plugin is almost a reason to buy Rhino alone) http://www.grasshopper3d.com/
