I have created a Pipe using the "Insert - Advanced - Pipe" option in Wildfire 5.0 that passes through 3 different Datum Points.
When I create a drawing for the same is there a way I get the location information (x,y,z positions) of these 3 points from the default CSYS of the part automatically?
regards,
Amarkarthi
Hi Amar,
You have to create a feature with the measured distance between the WCS sperately to X,Y & Z axis.
Now, in relation fectch those values of local parameter and add a relation.
After that create a drawing, insert a table and with the "&" and pull the values respectively.
Hope this works !
Amit
