Graphic Problem with Creo 1.0
ptc-5117227
Hello community,
I'm a student and at the university we start using creo 1.0. My problem is that I can't use it correctly because of an graphic problem. The part of window I draw is completly twisted. It's like I'm looking looking from the back of the screen and the courser is mirroed about the middle of the screen. Do somebody knows how I can solve the probem?
Please help me I become insane without an solution.
Thanks!
1 ACCEPTED SOLUTION
Max,
add graphics win32_gdi at the end of config.pro file.
Martin Hanak
Martin Hanák
Dale_Rosema
(To:ptc-5117227)
If you search on graphics, there are several items related to problems with graphics and graphics cards. I am not sure if this one helps, but check out:
http://communities.ptc.com/message/200061#200061
Also try setting you computer to OpenGL and see if that helps.
Max,
Martin Hanak
Martin Hanák
Thank you! Now everything works!:-)
