I possess the student version of Creo Parametric 2.0 and have the following problem:
Whenever I want to turn my part, I can't do so. For any reason, ctrl. + the right button of my mouse does not work. If I want to select several surfaces, the ctrl. key works. I also can't slide in the same level. Has the handling changed from 1.0 to 2.0? Is there a possibility to change/show my assignement of keys?
Thanks for your help!
Hello Jan.
Could it be that your mouse button has been re-assigned? Nothing should have changed from Creo 1 to Creo 2.
Can you please helpme? I have the student edition of creo. I installed it as directed, but when I try to open it, it says xercesc280mt.dll is missing. When I check in the MED folder, it is there. What should I do?
Hello and welcome to the forum, Adelar.
It wouldn't be the first time a path statement is missing in PTC products. You can try one of two things:
Copy the .dll file to your system's folder where other system .dll files exist, or you can add a path to the location where the not-found file is actually located.
You might also let Tim Brotherhood know you are having this issue through the forum private messages...
Hello Antonius,
I also thought about that, but I couldn't find out where I can change those mouse button settings.
