Helical sweep help
SOLVED
Helical sweep help
I am making threads for a part, and they are starting and ending at the middle of the part. How do i get the threads to be continuous?
D
1 ACCEPTED SOLUTION
Re: Helical sweep help
Danielle,
I hope i have understood your query correctly. Yes, you can change the end of threads by changing the trajectory for the sweep profile. Observe the end tip of the trajectory profile and sweep also.The attached the images are self explainatory. Let me know if there is any misunderstanding of the query.
Danielle,
