Help with sheetmetal drawing
Newbie
Is there a way to show the unbend form of sheetmetal when creating a drawing? I've searched everywhere to find an option to insert a view that would allow me to use a different representation as in the part modeling mode, but haven't found it. Please if anyone can help me. Thanks, Jay
7 REPLIES 7
Unbend Rep
Jay, One quick workaround is to do a SaveAs version of your model in the Unbend state, and add that model to your drawing. (I'm assuming you are talking about Unbend, as opposed to Flat Pattern. The latter is regularly and easily shown in drawings.) David
Unbend Rep
Jay, Should have added that you CAN create a Simplified Rep of the part that excludes the Unbend feature(s) and use that rep instead of your Master Rep to show the part without the Unbends. Then, perversely, use the Master Rep or a third rep to show the Unbend variation. (The problem is: you can't exclude features from your Master Rep.) David
RE: Unbend Rep
Make the unbend the last feature in your model tree, and make a family table with the part WITH the unbend feature as an instance (i.e. XXXX-XXXX_UNBEND.PRT), then supress the unbend in the generic. Add both models to your drawing, and use the generic for all your finished part views, and use the instance for the flat pattern. We do it all the time here.
RE: Unbend Rep
Thanks for your help guys!
RE: Unbend Rep
A rather simple function that PTC has had forever, but fails to direct everyone to it is this command EDIT/SETUP/FLAT STATE This will automatically give you the family table with the correct suppressed, unbent, and other features. While in the drawing use the add model to drawing and pick the flat-state instance to add to drawing. Make sure to set flat pattern to current model and place the view.
Re: Help with sheetmetal drawing
This is proper solution as you use same part to make drawing so that no problem of mismatch.
I wonder if anyone uses the method of having the master rep be the flat state and adding to the model a pre-defined flexibility with the "flat pattern" feature being the variant.
Upon upon assembling such a component, you are prompted with the variable items dialog box, where you can turn off the "flat pattern" and thus assemble the part in the "formed" condition.
For drawings, the model would have a "Formed" simplified rep in which the feature is excluded.
One problem with using the flexible models is that they are harder to replace.  But on the other hand, you "avoid" family tables.
I don't recommend doing this; I think the proper way is to have the flat-state be a family table instance of the formed generic part.
There are existing toolbar commands that make the process pretty quick:
1) create the flat pattern feature; suppress it and continue working on the model.  The flat pattern feature will be always pushed to the end of the model tree.
2) create the family table instance in which the flat pattern feature is resumed
