Try adding the cosmetic holes in sections,(mulitple features)and hide the section that is giving you the interferance. If you are doing a layout or a print, convert the view into draft int. (Turns the view into 2d and breaks the tie with the model). And just delete them manualy. If you need to keep the view live, try making a family table and use it for the view as needed.
