Hole Table not showing?
Now I would like to create a pattern of holes on a plane other then the front plane.
How do I get the hole table to show up in the drawing?
Need to know what you've done already. You need a coordinate system on the face the holes are created on the the Z axis oriented with the holes axes.
Here are some hole table discussions that may be of help.
I have problem regarding Hole table placing in Drafting
Hopefully these will help.
