As in first reply you can call SMT Thickness in repart region table by adding &asm.mbr.SMT_THICKNESS (Report parameter > asm > mbr > user defined > Type SMT_THICKNESS)
Do you want this to be added in Repeat Region? If yes, you can add &asm.mbr.SMT_THICKNESS.
Or Is it for "Bill of material" from Tools > Bill of material . In this case you need to customize BOM format file.
Thanks.
Its working.
