How can I filter a repeat region by rpt.index?
SOLVED
Participant
I have Creo 2.0 M080 and won't be upgrading for a bit. In the mean time, I have problems with parts lists that are taller than the height of my page. If I use paginate, I have to clear and reset the extent every time I regenerate. This is fine for tables on the same page, but tables spanning multiple pages really have issues. I have an idea for a workaround for the time being by adding additional parts lists tables and filtering out what the other lists show. I would like to use rpt.index to filter sections at a time; for instance I tried to use &rpt.index<28 in one and &rpt.index>28 in the other to imitate a single paginated table. However, the filter did not filter the correct lines.
Has anyone tried to do this and been successful?
1 ACCEPTED SOLUTION
Highlighted
Re: How can I filter a repeat region by rpt.index?
Shawn,
I tested your request just now.
1.]
Before you define a filter, you have to fix indexes.
In TBL REGIONS menu click Fix Index, select repeat region and then choose Fix > Region > Confirm > Done
2.]
Define filter
&rpt.index<=28 ... less or equal
-OR-
&rpt.index>28 ... greater then
Martin Hanak
Martin Hanák
3 REPLIES 3
Highlighted
Shawn,
1.]
2.]
Define filter
-OR-
Martin Hanak
Martin Hanák
Highlighted
MartinHanak‌-
What version are you using to test? I did forget to fix all my indices; I had manually reordered my parts list by fixing some and sorting the rest. However, after fixing the entire region, I still didn't get the results I expected (see below).
Highlighted
Shawn,
I fixed repeat region, only. I didn't make any other action on repeat region. I am sending test data created in CR2 M070.
Martin Hanak
Martin Hanák
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
