I want to show Inox material on my part. (Like Picture A.) But I try it that like picture B. It doesn't like metal material. Even if I use HDR, it doesn't like Inox. I don't know how can I show Inox material on my part.(Like Picture A.) Anybody can teach me? Thank you for your replying.
A
B
If I understand you right, you are concerned that metal surface (Inox = stainless steel) looks pretty dark, right?
I can see this happening for Photolux compared to Photorender. So I assume you use photolux, right?
Photolux is known to render darker for the default settings. Try to increase light Intensity in the Room Settings slightly (e.g. using 2.00 instead of 1.00) and make sure the light reflects into the camera.
Hi Gunter,thank you for your replying. Yes, I need the stainless steel. Like my picture
But I use Photolux in my model. I try to increase light and it does not look dark.
