How do I rotate an object in a creo drawing?
SOLVED
Newbie
Hello everyone,
I have my front view set up in the drawing, but I want to rotate it. About an axis or a feature, either way. How would I accomplish that?
Tags (1)
1 ACCEPTED SOLUTION
Highlighted
Re: How do I rotate an object in a creo drawing?
Select View > Right click > Properties.
8 REPLIES 8
Purva,
You can try using View orientation in view properties, possibly View orientation > Angle will help you.
Hi Mahesh,
I cannot seem to find the Angle option. Under view, there's view>orientation. I can't find the angle command. Could you help me with that? Thanks a ton!
select your view you wish to re-orient and RMB > properties
your options become available
Highlighted
Purva,
Did the reply in this post help you?
Hi Mahesh,
I apologize for not marking the correct answer earlier. The answers in the this post definitely helped me, thanks to you and Ron St. Pierre!
right click on the view, and click properties, when you drawing view, click view type and change [ type box from projection to general, then you will see angles option on the gray out, just click apply, it will be active. From there you can rotate any direction.
thanks, yaboneh
Hi
I am wondering if you know how to add the orientation symbol in the drawing?
Regards
Najib
LiveWorx Call For Papers Happening Now!
