How draw corrugation Tube?
sliu-4
1-Newbie
We always draw corrugation tube with "helical sweep" , I don't think it is ok, because the tube is continue, but helical sweep should not continue, it is only helical, how draw it?
6 REPLIES 6
attach a picture of requested shape.
MH
Martin Hanák
TomD.inPDX
(To:sliu-4)
If I understand, you do not want the helical part of the sweep, right?
If this is correct, have a look here...
Creating bellows with VSS and trajpar?
This was created with Creo 2.0 commercial version using VSS.
This can be tricky to get a highly accurate version, but for a representative version, this is probably the most robust.
it is helical part, but it is continual part, wondering whether helical sweep is not continual if magnify it? was it similar as spring? this is my concerning point it is. because I need to assembly the part into connector so that emulate data will be ok.
TomD.inPDX
(To:sliu-4)
A lot of zooming issues are graphic anomalies, not geometric.
vrajan
(To:TomD.inPDX)
Thanks for your reply
We are already aware of trajpar but we need it in a rectangular slots.. see the image closer.. its not round shaped edges its a linear shaped guard.. Zoom the picture where it is marked with arrow
Kindly tell me if there is any option to do like that
Thanks & Regards,
Vivek Rajan N
