How to add Piping Info ( Bend Location & Bend Length ) in creo drawings
ptc-5425836
2-Guest
Can anyone help me to add Piping Info ( Bend Location & Bend Length ) in creo drawings.
All i need to do is- there should be table of piping info which would automatically calls the piping parameters.
What values should I assign ( During repeat region ) to crea table so that it will pulls the bend machine & bend loaction info generated in model.
1 REPLY 1
jfontana
(To:ptc-5425836)
you can add bed tables to your creo drawing that state most of that. I would would look at
Line Stock
asm.mbr.pipe.stock...
Pipe Line
asm.mbr.pipe.line...
Pipe Segment
asm.mbr.pipe.segment...
Pipe Segment Bend
asm.mbr.pipe.segment.csys
Most of this is covered in the PTC Piping class. If you are interested in training let me know.
