Can anyone help me to add Piping Info ( Bend Location & Bend Length ) in creo drawings.
All i need to do is- there should be table of piping info which would automatically calls the piping parameters.
What values should I assign ( During repeat region ) to crea table so that it will pulls the bend machine & bend loaction info generated in model.
you can add bed tables to your creo drawing that state most of that. I would would look at
Line Stock
– asm.mbr.pipe.stock...
• Pipe Line
– asm.mbr.pipe.line...
• Pipe Segment
– asm.mbr.pipe.segment...
• Pipe Segment Bend
– asm.mbr.pipe.segment.csys
Most of this is covered in the PTC Piping class. If you are interested in training let me know.
