Using Creo Parametric 2.0
I'm making a drawing and I projected a section view out of a projected view of the same scale which is different from the rest of the model drawing. The section name is there, but not the carried over scale. I don't have it in my mind to add projection arrows to reference the other view because there's already many dimensions surrounding the parent view. I've learned that to reference a view scale, Creo says "&view_scale", but any time I do this it thinks I'm trying to add a view parameter and forbids it. Other than the obvious "Just do it manually" (I'd rather have adjustability), is there a way to link the view parameter I want with the text in the note? Recreating the view does not help.
-Christopher
That's it! Thanks!
