How to change number of digits in repeat region
I need your help with active_draving.dtl file setting-up so that i would have one more digit (4gigits) in a red colored column in the drawing
as below. It is just a family table with a parameter "MASS" - I cannot find the right option in dtl file to make the number more accurate.
Thanx a lot in advance
Tom
Tags (2)
6 REPLIES 6
Re: How to change number of digits in repeat region
Just guessing as I don't use repeat regions... can you use the [.4] at the end of the variable in the table?
Do you mean the table in drawing, family table in part or the variable in relations?
here some printscreens:
[.4] after a numeric parameter overwrites the default number of digits to 4.
Antonius means your drawing table.
Instead of the "&fam.inst.param.value" in your repeat region table try "&fam.inst.param.value[.4]"
Btw is this a 2D repeat region? Looks like you have two regions in your table.
Let us know how that worked out for you.
Yes, thanks for clarifying, Jakub
in drawing under layout--format--decimal places, fill the number of digits you want, then select the one or group by crossing over you want to change, done. Bill
