How to change transparency of a part and how to capture a screenshot in Creo 3
syang-5
1-Newbie
I am wondering if you can change transparency of a part in creo 3 and how to make screenshot in Creo 3? Thank you
1 ACCEPTED SOLUTION
I'm in CP2 and I think CP3 will be similiar
select the part
click the view tab
pull down the munu from the model display section
select component style then transparent
one simple way, because I do not know what your intent is with the screen shot:
ctrl-prtscrn
paste in paint (select paint graphic area >ctrl-v)
4 REPLIES 4
select the part
click the view tab
ctrl-prtscrn
Thank you Ron. It works.
Dale_Rosema
(To:syang-5)
Don't forget to mark the answer as correct for those who may find this in the future.
You can also change the appearance to a transparent material.
You can copy and edit appearances also.  Find the render tab.
